Forums >> Revit Building >> Technical Support >> Is there a way to "noplot" some of the section tags?
Fri, Nov 10, 2006 at 12:48:32 PM | Is there a way to "noplot" some of the section tags?
Motorcity
4 Stars: 2 Votes
In some cases, we don't always reference all of our section cuts. We may have some that are simply there for working purposes.  So, is there a way to make the unreferenced section tags "noplot" so that they do not show up on the sheets?
Motorcity Job Captain VOA Associates, Inc.
Fri, Nov 10, 2006 at 2:20:48 PM | Is there a way to "noplot" some of the section tags?
File - print - setup - click on hide unreferenced views.  You can also right click on the tag in the active view and select "Hide Annotation in View".  This will hide the tag only in that view.  To resore, roll over where the tag was and when it appears, right click and select "show Annotation in View."
Fri, Nov 17, 2006 at 9:02:44 AM | Is there a way to "noplot" some of the section tags?
Motorcity
4 Stars: 2 Votes
Thank you. That was very helpful. Our final plotting is right around the corner!
Ceiling Plan tags in Linked Model Views "Moving" (2010)
Tue, Dec 21, 2010 at 7:20:58 AM
Section tag font not changing in "side" section tags
Thu, May 22, 2008 at 9:21:54 AM
callouts with "typ" label?
Mon, Sep 15, 2008 at 1:44:41 PM
Section Tags missing (again)
Wed, Aug 26, 2009 at 10:50:38 AM
room tags in section
Wed, Jan 10, 2007 at 11:22:58 AM
Page generation time: 0.6282
