16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Inserting stone into brick veneer
I am trying to insert a portion of stone veneer into a brick veneer wall. For the elevation, just created a window opening with a stone insert. It works for the elevation but when I cut a wall section it doesn't look right. Was wondering if any body had sugguestion on how to show this correctly. I have attached a pdf of the elevation and section. Thanks
Instead of a window opening, try edit wall profile and cut out your square where needed, than insert the stone wall HTH
Stone Wall |
Tue, Aug 20, 2013 at 3:55:33 PM
Stone Walls, Stone Veneer, etc |
Fri, Oct 6, 2006 at 8:21:58 AM
Stone Veneer and Framing Plan |
Wed, Nov 14, 2007 at 12:12:22 PM
brick veneer window insertion question |
Tue, Nov 23, 2004 at 4:28:49 PM
Brick veneer stepping at alternate elevations |
Wed, Aug 14, 2013 at 8:28:36 PM
