Forums >> Revit Building >> Technical Support >> Cove Ceilings
Fri, Nov 10, 2006 at 12:37:12 AM | Cove Ceilings
simonpeterong
simonpeterong Avatar
5 Stars: 3 Votes
Greetings! First time to post a thread here. Newbie.. Hehe..
 Anyway,
 Is there a possibility to create ceiling coves?
Thanks! Much appreciated
Fri, Nov 10, 2006 at 1:38:50 AM | Cove Ceilings
eldados
eldados Avatar
4.5 Stars: 8 Votes
Hey mate, welcome!
when you say ceiling cove, do you mean reccess? I normally just draw the bottom part and the top part of the ceiling, that way it's faster and you are able to tag both parts, in a section or detail I fill in the gaps with some detail lines...
HTH
Integrator
KarelCAD
Fri, Nov 10, 2006 at 3:25:45 AM | Cove Ceilings
simonpeterong
5 Stars: 3 Votes
yes hehee..
oh is that it? thanks for the help i"ll go try it later :D
Fri, Nov 10, 2006 at 8:48:33 AM | Cove Ceilings
If you want to model it, you can do an upper and lower ceiling then fill in the coffered area with a wall sweep using ceiling materials.
cove lighting?
Wed, Dec 7, 2011 at 2:23:00 PM
Cove lighting
Mon, Mar 9, 2009 at 8:17:17 PM
Complex ceilings
Thu, Oct 8, 2015 at 1:02:54 PM
How do I create a sweep with a light source?
Mon, Nov 17, 2008 at 1:33:08 PM
Editing Wall Profile in Plan View
Thu, Jan 8, 2015 at 7:03:13 AM
Page generation time: 0.2465
