Forums >> Revit Building >> Technical Support >> pattern files
Thu, Nov 9, 2006 at 7:11:39 PM | pattern files
rohit
1 Stars: 1 Votes
I am learning Revit through tutorials
 My project is to design my highschool in revit. So far, I have put in the foundation walls, the floor, the walls, the ceilings, the ramps and stairs
I want to apply textures (brick, tiles) to what I have built so far. I went through the galleries and I don't understand how everyone makes the buildings so realistic
I don't know how to make .pat files. I read that you can make them with photoshop but my photoshop wont save in that format
Is there any other program you use to make the buildings look like that?
Thu, Nov 9, 2006 at 7:45:23 PM | pattern files
eldados
eldados Avatar
4.5 Stars: 8 Votes
First,
your Revit comes with lots of pattern files, I'm sure you can find Bricks pattern there. you will need to go to your wall properties-->edit/new-->edit structure and change your material.
you can import ACAD .pat files into revit as well.
if you want to create a new pattern all together, there is a program that you will need to purchase, it's somewhere on the forums... Smile
Integrator
KarelCAD
Pattern (.PAT) Files
Mon, May 3, 2021 at 4:51:04 PM
Pattern files
Sat, Sep 16, 2006 at 5:11:34 PM
Use Pat Files
Tue, Sep 1, 2009 at 4:18:40 AM
11
Pat files corrupt
Thu, Jan 22, 2009 at 3:20:12 PM
Patern Files
Wed, Nov 16, 2005 at 2:53:56 AM
Page generation time: 1.4162
