Forums >> Revit Building >> Technical Support >> Plots which fail to plot to scale
Thu, Nov 9, 2006 at 5:53:38 PM | Plots which fail to plot to scale
huycke
3 Stars: 1 Votes
One of my students has a complete set of floor plans finished and dimensioned at 3/8" = 1'-0".  The view properties verify that the view is at this scale.  When the view is placed on an ANSI-D sheet, using the REVIT Residential template and plotted the views fail to plot at the stated scale.  On this student's station, I personally created a new project using the same residential template, and plotted my results and all was to scale.  Any advice would be appreciated.
Fri, Nov 10, 2006 at 12:01:30 AM | Plots which fail to plot to scale
eldados
eldados Avatar
4.5 Stars: 8 Votes
hmmm, strange,
the only thing I can think of (and I'm sure you check it) is the plot setting on his machine, current view, or visible portion of the view...
Integrator
KarelCAD
Fri, Nov 10, 2006 at 6:59:47 AM | Plots which fail to plot to scale
huycke
3 Stars: 1 Votes
Yes, I did check the plot settings.  Also sent his file to a different plotter in our room and came up with the same results.
Sat, Nov 11, 2006 at 10:14:27 AM | Plots which fail to plot to scale
holly1
Are you shure your plotting at zoom 100%
Tue, Nov 14, 2006 at 7:50:32 AM | Plots which fail to plot to scale
huycke
3 Stars: 1 Votes
holly,
thank you, i checked the zoom plot and it was off.  Once set to 100% all was well.
Printing: Window area for quick plots
Tue, Jun 5, 2018 at 10:06:23 AM
13
Dropped lines on plots
Tue, Mar 30, 2004 at 2:45:58 PM
Printing problem
Tue, Dec 13, 2005 at 4:20:07 PM
Annotation Scales
Sat, May 21, 2011 at 8:26:26 PM
Sheet title block plots incorrectly
Wed, Nov 3, 2010 at 10:44:30 AM
Page generation time: 0.1934
