Forums >> Revit Building >> Technical Support >> Rooms - editing room seperation lines
Thu, Nov 9, 2006 at 5:20:52 PM | Rooms - editing room seperation lines
vnd
3 Stars: 2 Votes
Is it possible to edit room seperation lines positions, ie: the shape of rooms?
VND
Thu, Nov 9, 2006 at 5:34:46 PM | Rooms - editing room seperation lines
dduarte
dduarte Avatar
3 Stars: 2 Votes
Yes, if you want to divide a room use the room separation tool. If you want to join two room make the wall between them not room bounding.
David
Fri, May 16, 2008 at 3:45:19 PM | Rooms - editing room seperation lines
SaraN
But if the room separation line is already been drawn, is there a way to modify it or do you have to redraw?
Fri, May 16, 2008 at 5:29:29 PM | Rooms - editing room seperation lines
dduarte
dduarte Avatar
3 Stars: 2 Votes
You can modify it like any other linetype.
David
Mon, Mar 8, 2010 at 5:01:05 PM
Deleting Rooms
Sun, Aug 26, 2012 at 8:47:46 PM
Room seperation lines
Fri, May 12, 2006 at 5:19:35 PM
Room seperation
Fri, Dec 11, 2009 at 3:31:54 PM
Rooms!!!
Wed, Dec 12, 2012 at 12:24:13 PM
Page generation time: 1.4839
