Forums >> Revit Building >> Technical Support >> ELEVATION TAG CAN'T PRINT
Thu, Nov 9, 2006 at 9:03:37 AM | ELEVATION TAG CAN'T PRINT
wujesse
Hi, guys
I have two question regarding elevation tag.
1. few days ago, I place some new elevation tag in my plan and reference all the elevation arrowhead, then print. only the primary arrowhead can be printed, that doesn't happen before, and i found out the rest of arrowhead become dark grey color, it's hard to tell the difference if you don't look closely. did i do something wrong? how can i fix it?
2. I have  some exposed structural columns in my corridor, and the elevation only show column as a thick line not in real thickness. i try to cut a section to see what happpened, it's the same. only lines. How can i make the column show its true thickness?
thank you very much
Thu, Nov 9, 2006 at 11:04:26 AM | ELEVATION TAG CAN'T PRINT
gdoorn
1 Stars: 1 Votes
FOR THE COLUMS TURN THE DETAIL LEVEL TO MEDIUM OR HIGH (BOTTOM LEFT CORNER OF THE VIEW WINDOW NEXT TO THE SCALE.
Thu, Nov 9, 2006 at 12:21:50 PM | ELEVATION TAG CAN'T PRINT
wujesse
THANKS, MAN
HOW ABOUT THE TAG CAN'T PRINT? ANYONE?
elevation arrowhead don't show up at print
Tue, Nov 14, 2006 at 1:26:57 PM
Elevation Tag Doesn't Work in Rotated Viewport!
Wed, Aug 10, 2016 at 6:16:18 PM
Interior Elevation Tag
Wed, Dec 19, 2012 at 2:25:25 PM
elevation tag line weight
Wed, Dec 17, 2008 at 1:55:39 PM
Interior elevation tag
Wed, Apr 8, 2009 at 11:30:17 AM
Page generation time: 0.7743
