22 Users Online (20 Members):
Forums >> Revit Building >> Technical Support >> Site Plans
1 Posts No Rating |
I'm going through the site plan tutorial and having trouble with the slab being level!! you're supposed to put points where you need them, but it doesn't seem like there's any control to them. Any Suggestions??
THE POINTS ARE FOR THE SPOT ELEVATIONS OF THE LAND -- NOT THE FOUNDATION OF THE BUILDING.YOU MAKE THE LAYOUT OF THE LAND FIRST BY USING THE TOPOSURFACE TOOL, AND THEN ADDING SPOT DIMENSIONS AS REPORTED ON THE SITE PLAN/SURVEY. THIS STEP GIVES YOU THE COUNTOURS OF THE LAND.THEN, YOU ADD A "PAD" AFTER THAT TO SET THE BUILDING ON, CUTTING INTO THE LAND YOU JUST DREW. THE PAD (SLAB) WILL BE LEVEL.TRY IT AGAIN, I'M SURE YOU CAN GET IT!IT TOOK ME A WEEK TO BE COMFORTABLE WITH TOPOSURFACE, SO DON'T WORRY.-M
----------------------------------- CRI |
site plans and buildings plans |
Tue, Apr 17, 2012 at 8:40:07 AM
Site Plans |
Wed, Jun 17, 2009 at 7:32:59 AM
Utility lines on site plans |
Fri, Sep 15, 2006 at 1:01:29 PM
3D Site Safety Plans in NYC |
Fri, Apr 8, 2016 at 4:18:09 PM
Site plans and Linking with Master files |
Fri, Jul 7, 2006 at 6:55:40 PM
