Forums >> Revit Building >> Technical Support >> Why am I seeing the stairs through the floor?
Mon, Nov 6, 2006 at 1:43:26 PM | Why am I seeing the stairs through the floor?
syzygy
hello,
 I've encountered a visualization problem.  on the second floor, floorplan, the floorslab extends over a long staircase.  The floor slab has been edited to make an opening to allow for the stairs to reach the second floor but only the necessary amount.  for some reason, the whole stair is showing on the second floor plan.
 Thanks a ton for the help!  I've encountered this before but, apart from doing a filled region in drafting view to cover it up, I don't know how to get it to stop showing like this and plotting as shown.
Tue, Nov 7, 2006 at 11:33:59 AM | Why am I seeing the stairs through the floor?
Are you sure you have your slab on in your visability settings?
Did you temporarily hide the slab?
Tue, Nov 7, 2006 at 11:48:10 AM | Why am I seeing the stairs through the floor?
syzygy
the slab is on in the visualization settings.  the ONLY thing from the floor below i'm seeing is the continuation of this stair.  nothing else.  it's weird.
Tue, Nov 7, 2006 at 12:36:06 PM | Why am I seeing the stairs through the floor?
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
Hello,
You could try going into the view properties and set both the bottom primary and the view depth to be zero on that level.
If you have done this, maybe you could post the file so we could look at it.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Tue, Jul 8, 2008 at 10:54:39 PM | Why am I seeing the stairs through the floor?
rqtecht
This reply is well after the question but I just ran into this issue in 2009. In case anyone else comes across this post...
I found out it was due to my view range top setting. It was set to unlimited. When set to unlimited, it showed the stairs through the slab. When I changed the top setting to the upper level clg, stairs were hidden by floor slab.
Revit's collor fill hides floor slab floor slab doesnt hide stairs anymore
Thu, Feb 8, 2007 at 2:08:28 PM
Stairs to second floor showing full stair
Thu, Jun 4, 2015 at 9:44:02 AM
12
2 sets of stairs, 1 landing, 1 cutback. possible?
Sun, Mar 1, 2009 at 3:28:10 AM
Can't Change Stairs In Floor Plan Without Other Flloor Plans Changing As well
Wed, Dec 25, 2024 at 7:45:36 PM
Help w/ stairs [ 1 2 ]
Sun, Jan 9, 2011 at 11:47:33 AM
18
Page generation time: 1.7798
