Forums >> Revit Building >> Technical Support >> DISGRUNTLED GROUPINGS
Tue, Nov 2, 2004 at 3:57:49 PM | DISGRUNTLED GROUPINGS
rubiks cube
Hello, I am working on a multifamily residential pet project. I want to be able to communicate with autocad 2004. Since there are repeated unit types ie. UNIT_A How can I group and repeat units in revit, so that when they are exported as a DWG, the groups end up as BLOCKS in autocad? Is this possible? Can "blocks" be created in revit? crawf
Mon, Nov 29, 2004 at 4:43:11 PM | RE: DISGRUNTLED GROUPINGS
lisab1070
4 Stars: 1 Votes
You can create blocks in Revit for use in AutoCAD by creating a family. Any family in a project file that is exported comes into AutoCAD as a block. For the multi-units, you will probably find it easier to export the project and then turn them into blocks rather than creating multi-unit family files.
Mon, Nov 29, 2004 at 4:55:58 PM | RE: DISGRUNTLED GROUPINGS
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You could also use linked files, as when exported will also become a block... Ie: create a project for your unit design, then create another project for the campus and link the units into that... (only problem will be if you plan on scheduling in revit...
Browser Organization and Drawing List
Mon, Jul 26, 2010 at 3:49:09 PM
rooma area of several room areas
Mon, Apr 19, 2010 at 1:34:38 PM
best method of BIM coordination
Thu, Jan 26, 2017 at 7:57:23 AM
Section Line errors
Wed, May 23, 2012 at 12:48:48 PM
new user - copying grids to other levels
Mon, Dec 6, 2010 at 3:06:35 PM
Page generation time: 1.9199
