10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Toposurface and ACAD files
When created a toposurface using an imported Autocad site plan, how can one assign different grade elevations automatical. When I do, it gives me all the points along the new contours, but they are all at one elevation. How can I change that easily, without having to change each point individually. If someone can help, thanks in advance.
In autocad give each contour the correct z elevation. Hopefully they will be polylines and it will just be a matter of moving it up the appropriate amount...
3D Acad model to toposurface |
Fri, Jun 15, 2012 at 6:29:51 AM
Fatal Error when linking/importing ACAD files |
Fri, Aug 15, 2008 at 12:43:27 PM
Toposurface from Autocad File |
Mon, Oct 6, 2008 at 4:06:02 PM
toposurface |
Fri, Sep 8, 2006 at 5:40:55 AM
Exported file to ACAD has problems with custom PATTERNS [made in acad] |
Mon, Jun 23, 2008 at 3:21:32 PM
