Forums >> Revit Building >> Technical Support >> Minimum / Maximum Parameters
Thu, Nov 2, 2006 at 10:05:46 PM | Minimum / Maximum Parameters
Sumex
Sumex Avatar
Does anyone know how to set Length Parameters to minimum and maximum values.  I'm trying to set a length to >= and <=...
ThanX...
Fri, Nov 3, 2006 at 2:04:26 PM | Minimum / Maximum Parameters
TomDorner
4.5 Stars: 25 Votes
There is no min/max function present in Revit.  You can limit a parameter to a certain range though with an IF or nested IF statement.  Below is the Revit help file which explains it pretty well.  Post again if you get stuck.
You can use conditional statements in formulas to define actions in a family that depend on the state of other parameters. With conditional statements, the software enters values for a parameter based on whether a specified condition is satisfied. Conditional statements are useful in certain circumstances; however, they make families more complex and should be used only when necessary.
For most type parameters, conditional statements are unnecessary, because the type parameter itself is like a conditional statement: If this is the type, then set this parameter to a specified value. Instance parameters are a more productive place to use conditional statements, particularly when they are used to set a parameter that does not vary continuously.
Syntax for Conditional Statements
A conditional statement uses this structure: IF (<condition>, <result-if-true>, <result-if-false>Winking
This means that the values entered for the parameter depend on whether the condition is satisfied (true) or not satisfied (false). If the condition is true, the software returns the true value. If the condition is false, it returns the false value.
Conditional statements can contain numeric values, numeric parameter names, and Yes/No parameters. You can use the following comparisons in a condition: <, >, =. You can also use Boolean operators with a conditional statement: AND, OR, NOT. Currently, <= and >= are not implemented. To express such a comparison, you can use a logical NOT. For example, a<=b can be entered as NOT(a>b).
The following are sample formulas that use conditional statements.
Simple IF: =IF (Length < 3000mm, 200mm, 300mm)
IF with a text parameter: =IF (Length > 35', “String1”, “String2&rdquoWinking
IF with logical AND: =IF ( AND (x = 1 , y = 2), 8 , 3 )
IF with logical OR: =IF ( OR ( A = 1 , B = 3 ) , 8 , 3 )
Embedded IF statements: =IF ( Length < 35' , 2' 6" , IF ( Length < 45' , 3' , IF ( Length < 55' , 5' , 8' ) ) )
IF with Yes/No condition: =Length > 40 (Note that both the condition and the results are implied.)
Tom
www.reviteer.com   http://twitter.com/Reviteer
Fri, Nov 3, 2006 at 2:07:45 PM | Minimum / Maximum Parameters
Sumex
Sumex Avatar
You're the man...  I'm cheking this out now......
RAC 2013 - Transfering wall parameters between projects
Tue, Jun 25, 2013 at 11:58:23 AM
Existing Stairs
Mon, Aug 10, 2009 at 1:36:53 AM
600dpi maximum rendering for RAC2009???
Wed, Oct 21, 2009 at 11:58:23 AM
Curtain Wall Maximum Spacing
Wed, Jul 18, 2012 at 2:14:40 PM
Revit Maximum FOrmula
Thu, Jun 9, 2011 at 11:36:58 AM
Page generation time: 5.0602
