Forums >> Revit Building >> Technical Support >> modifying generic 8"inch wall to brick over stud
Wed, Nov 1, 2006 at 6:52:40 AM | modifying generic 8"inch wall to brick over stud
huycke
3 Stars: 1 Votes
One of my students has built a two level house. Both levels, 1st floor and 2nd floor are created with 8" generic walls.  He went to convert them to brick over stud and when he did, the upper level coverted....and recessed about half a wall thickness.  I checked to see that the generic wall was "facing out" and of course it was, otherwise the brick wouldn't have been visible anyhow, but yes, the wall actually recessed for some reason.  We tried the align option to no avail.  Any ideas please?
Wed, Nov 1, 2006 at 9:05:58 AM | modifying generic 8"inch wall to brick over stud
bolandereric
Check the location line If you drew the first level with the location line set at exterior face and then the second floor as wall centerline.  This could be your problem check it out.
Window in brick/stud wall
Fri, May 26, 2006 at 2:43:48 AM
Existing 12" wall w/4" brick-4" cavity-4" brick. Can't get plan brick to s
Wed, Apr 8, 2009 at 5:08:39 PM
Window Placement in Stud/Brick Veneer Wall [ 1 2 ]
Wed, Feb 4, 2009 at 11:22:19 AM
15
RAC 2012: Window Trim Reveal in brick/Stud Wall
Mon, Jul 2, 2012 at 2:08:10 PM
Mixing of brick and block patterns and not aligning
Fri, Jun 23, 2017 at 9:40:16 PM
Page generation time: 2.2191
