19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> elevation tags
10 Posts No Rating |
I want to change the style of the elevation heads in plan view, but as usual I cant even find let alone open the standard one to edit it ....any suggestions much appreciated
1 Posts No Rating |
Alas, and unfortunately, these tags are "system" families. While there are minor modifications that you can make, you cannot "change" the tag to something different. (And an issue if I say so myself. State of Virginia has tag standards and requirements.) One more for the wishlist I guess. In order to make the minor changes though, select the tag and bring up properties. You can modify the tag to be round, vs. square, etc. there. Regards, Brian Ayers Saint Gross, Architects and Planners Baltimore, MD
thanks for the reply Brian
hi from brisbane mr spot had a great tutorial on his blog about making an elevation symbol from a section symbol. i did it on a project some months ago, and it was great. so - maybe the answer is, do something similar by creating a section symbol that matches your needs, then adjust as per mr spot's advice? search this forum for mr spot / elevation tag maybe?
Hiding View Name in Elevation View Tags |
Fri, Jan 21, 2011 at 6:47:39 PM
Elevation Tags |
Tue, Oct 23, 2007 at 4:30:06 PM
Custom Elevation Tags |
Thu, Mar 17, 2011 at 5:09:02 AM
2011 interior elevation tags |
Thu, Dec 23, 2010 at 11:44:57 AM
Multiple Elevation Tags |
Mon, May 24, 2010 at 3:20:16 PM
