Forums >> Revit Building >> Technical Support >> IMport from Archicad
Tue, Oct 31, 2006 at 8:10:59 AM | IMport from Archicad
rossdes
I have a consultant in Archicad, I'm in Revit 9.1. Is there a way to impoort his work into mine, and if so how does he need to save his files?
rossdes
Tue, Oct 31, 2006 at 8:16:38 AM | IMport from Archicad
coreed
coreed Avatar
4 Stars: 16 Votes
he can export his files out of Archicad as Autocad dwg files which you can then link into Revit
Edited on: Tue, Oct 31, 2006 at 11:10:55 AM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Oct 31, 2006 at 3:19:20 PM | IMport from Archicad
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The other option is they could export out of ArchiCAD to IFC.
Then in a new revit file you can import the IFC to have it generate the model.  This ability is still somewhat limited.  At least it was when i last looked at it, but its worth a try.
HTH
Regards,
Chris.
importing from archicad
Thu, Nov 27, 2008 at 10:55:38 PM
Architect is using ArchiCAD Structural Consultant using Revit?
Thu, Nov 27, 2008 at 11:23:30 PM
Revit vs. Archicad
Fri, Sep 28, 2007 at 11:57:54 PM
14
Converting a Revit v 8.0 file into Archicad v10.0
Tue, Mar 24, 2009 at 4:21:51 PM
Wish it looks like ArchiCad
Fri, Nov 28, 2008 at 2:26:55 AM
Page generation time: 0.1411
