Forums >> Revit Building >> Technical Support >> CHanging color of walls/roofs
Tue, Oct 31, 2006 at 7:53:06 AM | CHanging color of walls/roofs
lschwarzweller
I'm relatively new at Revit, and I am having troubles changing the colors of the walls.  In the wall properties i know how to edit the exterior color and it shows up how i want it in 3D mode, but when i go to render it goes back to the original default color.  This is the same with the doors and windows. Any help please?
Edited on: Tue, Oct 31, 2006 at 8:14:14 AM
Tue, Oct 31, 2006 at 8:54:31 AM | CHanging color of walls/roofs
laurabh
In order to change the color of a material in a rendering, you have to assign accurender materials.  Under Settings --> Materials, the selection for material color under the heading "Shading" only applies to shaded views. The second heading "AccuRender" is where you set up your materials for acutal renderings (using the rendering tab).  You also might want to check that you're pointing to the AccuRender library by going to Settings --> Options, then click the Rendering Tab.  Check to make sure "AccuRender resource location" is pointing to the right directory.  If not, then all your materials will render gray.
Visibility issues for categories in Revit 2013
Thu, Aug 29, 2013 at 3:09:49 PM
Walls, Floors and Roofs to show hatch pattern AND color poche?
Sun, Apr 29, 2012 at 12:24:19 PM
Changing Wall Paint color
Sun, Feb 7, 2010 at 7:02:40 PM
walls and ceiling are same color
Sat, Jan 12, 2008 at 7:08:45 AM
Flat color on curved surface, same color on foreground & background
Wed, Aug 10, 2011 at 7:16:06 PM
Page generation time: 4.0981
