Forums >> Revit Building >> Technical Support >> Revit + windowblinds = bad combination?
Mon, Oct 30, 2006 at 3:01:05 PM | Revit + windowblinds = bad combination?
Urben
I've been running Revit Building for a while now without any problem.
Today I installed windowblinds (i was tired of the XP-colors.... - shame on me huh?), but since then Revit makes my PC crash...
 I will remove the dreaded software, but has anyone else had this probleme too?
Mon, Oct 30, 2006 at 4:12:44 PM | Revit + windowblinds = bad combination?
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes i did experience this.  Solution was simply to add revit as an exception in the windowsblinds settings so it isn't modified.
Regards,
Chris.
Wed, Nov 1, 2006 at 3:04:21 AM | Revit + windowblinds = bad combination?
Urben
Thanks!
 I switched it off, and no more problem! - I saw the option too in Windowblinds - I'll try it that way! Thanks again!
Combination Deck -Q-deck Floors
Thu, Sep 3, 2009 at 1:05:01 PM
Bad Curtainwall with Bad Joins v2015
Mon, Dec 21, 2015 at 1:54:27 PM
11
walkthrough file in bad quality
Sun, Jul 11, 2010 at 1:27:52 PM
Door & Window Combination Frame
Thu, Jul 31, 2008 at 5:43:32 AM
Cant Undo or Redo Because Elements are not Editable = Very Bad Revit
Wed, Apr 15, 2015 at 5:41:08 PM
Page generation time: 1.4014
