28 Users Online (26 Members):
Forums >> Revit Building >> Technical Support >> Batten Insulation - System Wall - Section
Has anyone setup a system wall so that it in a section view it automatically shows batten insulation? See attached image for example. I know about the Insulation drafting command. I understand the potential file size and performance issues. I came close to creating one, but I was having difficulties with positioning the batten insulation with the correct scale and angle.
Mark Mates
www.prosoftnet.com
The solution I came up with is to create a parametric line-based detail component and insert that into a profile family. The downside is that it will not adjust to the height of the host wall automatically. You'll basically have to set up family types for wall thickness and batting height. But in the end, once your wall heights are set, the insulation will automatically show up in that wall type. I've attached the line-base family I created and subsequently loaded into the profile family. HTH
Adam P. Nicholes
Revit Implementation Expert
nicholesap@msn.com
480.678.1710
LinkedIn
EXCELLENCE BEYOND EXPECTATIONS |
Your batt6 detail companent works great in a repeating detail component. just adjust the spacing for the different sized batt widths. =)
thanks for sharing!
How to make a curved timber batten wall? |
Tue, Jun 7, 2011 at 5:49:49 AM
Board and Batten wall |
Thu, Jul 14, 2016 at 3:11:00 PM
Keynote for System Insulation Line - RAC 2008 |
Fri, Mar 7, 2008 at 6:19:06 PM
System family wall |
Sat, Apr 11, 2009 at 9:19:21 AM
insulation line |
Fri, Dec 1, 2017 at 9:57:58 AM
