Forums >> Revit Building >> Technical Support >> true north in shadow diagram
Thu, Oct 26, 2006 at 1:23:33 AM | true north in shadow diagram
transit
i am currently working on a multistorey project. When trying to complete the shadow diagram i discovered project north was significantly different than true north. is there a way that i can artificially set true north. I don't want to rotate the drawing on that particular view as it would conflict with other worksets and due to the size of the document this would take forever. Thank you
Thu, Oct 26, 2006 at 3:37:01 AM | RE: true north in shadow diagram
nandini
you can create a new elevation and name it as true north. if you want the shadow to be insync with the true north, change the sun settings.
true north and plan north effect on sun angles
Mon, Feb 13, 2006 at 10:13:17 PM
Shadow Casting
Thu, Feb 12, 2009 at 10:00:48 PM
True north help
Tue, Jul 21, 2015 at 3:52:04 PM
Project North doesn't rotate back after changed to True North
Fri, May 7, 2010 at 3:24:14 AM
Shadows set using Geographic location relate to Project North not True North
Sat, Mar 4, 2006 at 2:15:27 AM
Page generation time: 0.3709
