Forums >> Revit Building >> Technical Support >> Increasing temp file with revittemp files using up c: drive space
Wed, Oct 25, 2006 at 8:49:19 AM | Increasing temp file with revittemp files using up c: drive space
Hi I have noticed that my c: drive has been hugely reduced in available memory and in searching for the used space I found this temp directory that is now 25 gigs. Any idea why this is not cleaning itself and what these revittemp files are and what I can do to rectify this? See image below of directory & size.
Wed, Dec 10, 2008 at 5:00:59 PM | Increasing temp file with revittemp files using up c: drive space
Jmarchese
I've actually just started having this problem.  I realize this thread is very old, but is anyone else experiencing this?
Tue, Mar 10, 2009 at 4:22:28 PM | Increasing temp file with revittemp files using up c: drive space
cdthoma
I am having this same issue.  Has someone addressed this issue yet?
Tue, Mar 10, 2009 at 5:13:42 PM | Increasing temp file with revittemp files using up c: drive space
This is not a Revit issue - it is part of your OS.  Use a cleaner program or delete the files yourself.
not enough space on temp for rendering
Wed, Feb 9, 2011 at 6:03:49 AM
Not enough hard drive space
Sat, Jan 8, 2011 at 6:09:16 AM
11
RENDERING CRASH...NOT ENOUGH SPACE???...HELP PLEASE!!!
Fri, Jun 26, 2009 at 7:08:39 AM
Revit Structure
Tue, Feb 14, 2012 at 12:17:40 PM
Local Files and Reformatting my Hard Drive
Thu, Jun 7, 2012 at 8:24:39 AM
Page generation time: 2.5226
