Forums >> Revit Building >> Technical Support >> Trees not casting shadows on shadow study??
Tue, Oct 24, 2006 at 6:52:54 PM | Trees not casting shadows on shadow study??
vnd
3 Stars: 2 Votes
I'm doing a shadow study, on a steep sloping site, and my trees don't cast shadows... is this usual... how do I get my trees to cast shadows?
VND
Tue, Oct 24, 2006 at 9:47:33 PM | RE: Trees not casting shadows on shadow study??
framerman
4 Stars: 13 Votes
dumb question, but do you have shadows turned on?
Tue, Oct 24, 2006 at 11:04:19 PM | RE: Trees not casting shadows on shadow study??
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Do you have a ground plane turned on or is there something for the shadows to be cast onto?
Regards,
Chris.
Tue, Oct 24, 2006 at 11:08:56 PM | RE: Trees not casting shadows on shadow study??
vnd
3 Stars: 2 Votes
ofcourse!
VND
Tue, Oct 24, 2006 at 11:10:12 PM | RE: Trees not casting shadows on shadow study??
vnd
3 Stars: 2 Votes
yes there is a ground plane & there are shodows from other objects like buildings etc... which work fine on the topograpy, just no shadows from trees.
VND
Tue, Oct 24, 2006 at 11:12:59 PM | RE: Trees not casting shadows on shadow study??
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Do the trees have a transparency setting on their material? Post a screenshot. May help rather than us playing the guessing game.
Regards,
Chris.
Wed, Oct 25, 2006 at 1:33:00 AM | RE: Trees not casting shadows on shadow study??
vnd
3 Stars: 2 Votes
Sure, here it is.
VND
Wed, Oct 25, 2006 at 1:50:40 AM | RE: Trees not casting shadows on shadow study??
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Simple answer, the trees you are using have a 2D representation in plan. Either make sure their 3d model is set to show in plan or use a 3D view orientated to top. HTH.
Regards,
Chris.
Wed, Oct 25, 2006 at 10:23:58 AM | RE: Trees not casting shadows on shadow study??
framerman
4 Stars: 13 Votes
Hehe, sorry. Had to ask the obvious first.
Wed, Oct 25, 2006 at 6:17:31 PM | RE: Trees not casting shadows on shadow study??
vnd
3 Stars: 2 Votes
how do you do set the 3d model of an object to show in plan?
VND
Thu, Oct 26, 2006 at 1:02:38 AM | RE: Trees not casting shadows on shadow study??
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
What tree are you trying to edit? Is it one of the metric library ones? As these are locked...
Sun, Apr 3, 2011 at 12:14:33 AM | Trees not casting shadows on shadow study??
mike102
3 Stars: 2 Votes
hey i had the same problem all you have to do is click on the tree that you are using>then under the modify tab click on edit the family>open up your 3d view of the tree>click on the visibility setting> then check the box that say plan/ocb> then click load into project. This will allow your tree to be 3d in plan view and cast shadows!
Some trees not casting shadows
Thu, Oct 16, 2014 at 10:55:22 AM
Revit 2011: Linked model not displaying casting shadows
Tue, Sep 28, 2010 at 1:55:13 PM
can i turn off 'casting shadow' function in a single light fixture in Revit2008?
Tue, Apr 14, 2009 at 5:59:08 AM
SHADOWS WENT LOCO...
Thu, May 24, 2007 at 5:41:18 PM
Help Glazing casting shadows in sun studies
Wed, Dec 16, 2009 at 7:19:40 PM
Page generation time: 2.2943
