Forums >> Community >> Newbies >> Assisted Living!
Tue, Oct 24, 2006 at 1:37:00 PM | Assisted Living!
jmiller
I am starting a progect for a assisted living facility and i am wondering what is the best way to do the room layouts! There are only a few differents layouts but of mutiple uses of the saem ones! I am thiniking that groups will be the best bet unless someoen has a better idea! Let me know!
Tue, Oct 24, 2006 at 1:59:02 PM | RE: Assisted Living!
derxaj
3.5 Stars: 3 Votes
Use groups but be carefull with them when it comes to any families that are surface mounted. Sometimes groups work perfectly and other times they are far from perfect, expecially when it comes to groups with ceilings and ceiling mounted objects.
Tue, Jun 10, 2008 at 11:14:59 AM | Assisted Living!
psemrau
GROUPS have worked very well for me, especially for repetitive units. Doing changes is very easy.
But I must admit, that I had a few issues with wall mounted families, that happens when you change walls that have fixtures attached to a different thickness.  There will be allways objects excluded from the group, a quick fix is to ungroup everything, delete the model group in your browser, then delete the "rebel" fixture, reinsert it on the new wall and regroup with the same name.
Wed, Jun 25, 2008 at 3:40:52 PM | Assisted Living!
lunchtrayrider
3.5 Stars: 7 Votes
okay im digging this up to add some advice.  I've done these sorts of projects and here it goes.
1.  Make rooms groups.
2.  any hosted families should also have their host located in the group. i.e.  floor hosted toilets are bad because your floor is most likely not located within the group.  wall mounted cabinets  that are hosted by the wall are bad because if they are located on a demising wall or corridor wall the demising wall and corridor wall isn't in the group.  this can cause problems with groups because if you edit the wall or floor (not in the group) it makes changes to the group and results in changes made to a group that didn't happen in group edit mode.  bad.
 3. objects excluded from group.   right click and select restore all excluded.  if the requirements for being there are met then the objects will return.  you don't necessarily need to upgroup, delete, regroup etc.
I like scooters. and motorcycles.
Living Roof Design
Fri, Aug 28, 2015 at 8:10:23 AM
Repeating Objects/Items
Mon, Aug 19, 2013 at 10:01:33 AM
Night-time lighting in renders
Sat, Oct 22, 2016 at 8:02:20 AM
interior layout help?
Sat, Dec 17, 2011 at 8:16:21 PM
Trying to create stairs
Mon, Mar 30, 2009 at 12:53:07 PM
Page generation time: 0.0190
