9 Users Online (7 Members):
Forums >> Community >> The Studio >> Create Elevation Tag in my style
9 Posts No Rating |
How can make a elevation tag in my style
Yuthana subpaya-agin |
5 Posts No Rating |
This is something I would like to know also. I am not a novice by any means but I cannot find the right callout head or anything to load into Revit. I have checked the tutorials but didn't find anything. Does anyone have anything on how to create a custom elevation tag?
here is question 9 from Mr. Spot FAQ at blog website. it may help with some insight
9. How do I change the elevation symbols to match my section markers?
This isn’t possible. Elevation tags are system families and can only be modified using the settings in the elevation tag properties… This is a long standing wishlist item.
My typically workaround (for times where its absolutely necessary that the elevations look a certain way) is to create a new section type called "Building Elevations" Then I'll give the section a head with no tail, then drag the section cut line in plan to be short enough that its not visible.
HTH
updating/changing elevation tag types |
Wed, Mar 19, 2008 at 9:49:46 AM
if I happen to put two elevations on different sheets on the same elevation tag |
Wed, Jan 12, 2011 at 3:00:58 PM
Incorporating a Spot elevation tag into a custom made pipe "size" tag |
Fri, Dec 13, 2013 at 8:28:38 AM
Adding a Tail to Interior Elevation Tag |
Fri, Mar 14, 2014 at 1:10:11 PM
Floor Tag elevation |
Wed, Nov 9, 2016 at 10:06:15 AM
