9 Users Online (7 Members):
Forums >> Revit Building >> Technical Support >> roof slopes/warps
i have a big-box project with a "flat" roof. we are sloping our framing, and tapering the ledger to achieve our "crickets". the problem is i originially modeled the project with the "hipped-roof" feature when applying slope arrows at the extents of the cricketing. however, i need the ridge-line of these warped zones to be sloped as well. (i am sloping from a grid line to the building perimeter, but the ridge line needs to be a certain height above the roof drain to achieve the minimum 2% roof sloping throughout.).
long winded question summed up is: is this possible to create all these custom slopes on a 'flat-roof'? or is it best to create 2-D linework (with filled regions to hide info) to more accurately represent the top of sheathing heights in building/wall sections?
35 Posts No Rating |
Perhaps you could use "roof by extrusion" to acheive the roof profile you need using linework then extrude that profile shape.
Just a thought.
----------------------------------- AutoCAD & Revit TAFE teacher from regional Australia |
revit roof slopes |
Tue, May 6, 2014 at 10:19:05 AM
Adding skylights and slopes to a roof |
Thu, Jul 12, 2012 at 8:33:07 AM
roof issue (even roof valley slopes with uncentered drain locations) |
Wed, Mar 14, 2012 at 12:25:14 PM
Roof Slopes |
Fri, Sep 24, 2004 at 11:17:08 AM
13
roof slopes with skylight openings and notch |
Wed, Apr 21, 2010 at 1:09:29 PM
11
