Forums >> Revit Building >> Technical Support >> Adding Room Tag Parameters
Mon, Oct 23, 2006 at 10:55:52 AM | Adding Room Tag Parameters
btomlinson
I am in the process of creating a template file for our office and would like to set up the room tag with a wall finish category for each of the following: North Wall Finish, South Wall Finish, East Wall Finish, West Wall Finish. By default, the room tag only has the Wall Finish parametere. How do I add the additional parameters without creating visible labels? Additionally, is there then a way to have the room tag read the finish material from the wall structure rather than having to manually enter the finish (Room Styles will not work, as we may have a room with multiple finishes and usually no two rooms are alike).
Tue, Oct 24, 2006 at 10:29:46 AM | RE: Adding Room Tag Parameters
TomDorner
4.5 Stars: 25 Votes
The "room finishes" in the properties of the room are simple dumb text fields. Unfortunately these fields are all you can display in the room tag. (You can of course add more via shared parameters). The function of these fields is limited to rooms with only four walls all with a uniform finish. They are holdovers from the earliest versions of Revit and most people cannot make use of them because of the complexity of real world construction. The finishes assigned to wall materials cannot display in the room tag. They could however be tagged via a keynoting system. You might want to explore "keynoting" in the Revit help menu. HTH Tom
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:40 AM
Room Tag With Ceiling Offset from level, or Ceiling High
Sun, Mar 8, 2009 at 11:03:00 PM
Adding a Numerical Level Parameter to a Room Tag
Mon, Jul 23, 2018 at 10:53:59 AM
Adding Room Number to Door Tag
Sun, Jun 23, 2013 at 9:14:46 AM
Custom room tag
Thu, Oct 9, 2008 at 9:28:49 AM
Page generation time: 0.3604
