Forums >> Revit Building >> Technical Support >> Different visibility setting in teh same view????help
Mon, Oct 23, 2006 at 9:08:17 AM | Different visibility setting in teh same view????help
wujesse
what i trying to do is that i have some toilets in the plan that i want to show but at the same time i have some sinks that i don't want to show in the document, and both objects are plumbing fixtures, so when i turn off plumbing fixture in visibility dialog. both of them turn off. and i can't change the truth that they are all plumbing fixtures. so i wonder that is there anyway i can isolate the bathroom area so i can show toilets and turn off plumbing fixture for the rest of the area? Mr. spot had suggest me to use filter, but i don't think that's what i need. do anybody out there knows what to do???if you can help me, i will very very appreciate it. thank you very much
Mon, Oct 23, 2006 at 9:13:09 AM | RE: Different visibility setting in teh same view????help
framerman
4 Stars: 13 Votes
you could make a project phase and give the sink one phase and toilet another.
Mon, Oct 23, 2006 at 10:22:14 AM | RE: Different visibility setting in teh same view????help
TomDorner
4.5 Stars: 25 Votes
Your best bet is to make a sink that uses a new category of plumbing fixture symbolic lines to control the visability of the sinks independantly. You would need to make or modify your sink family to include the new subcategory. A simple family with no 3D and only "sink" symbology is attached to reverse engineer. HTH Tom
Mon, Oct 23, 2006 at 2:11:56 PM | RE: Different visibility setting in teh same view????help
laurabh
I agree with Mr Spot - use a filter. It's the easiest route.
Layer Settings of imported Autocad drawings
Tue, Jan 18, 2011 at 3:19:31 AM
Locking Worksets Visibility
Fri, Nov 25, 2016 at 12:00:04 PM
LOSING USER VISIBILITY SETTING AFTER SYNCHRONIZING
Tue, May 29, 2012 at 10:08:53 AM
Hide Mullion Profile When the Visibility Setting is Fine
Mon, Mar 13, 2017 at 10:32:48 AM
I can not figure out teh "View Range" in revit 2013
Fri, Aug 30, 2013 at 12:54:18 PM
Page generation time: 2.7433
