Forums >> Revit Building >> Technical Support >> Gambrel Roof + Walls
Fri, Oct 20, 2006 at 11:54:15 AM | Gambrel Roof + Walls
Bedard
Please help! My walls are sticking straight up out of my (extruded) gambrel roof. The "attach" function is not working. When I try to attach the wall to the gambrel shaped roof, the wall goes berzurk and shoots off in different directions.
Fri, Oct 20, 2006 at 2:18:15 PM | RE: Gambrel Roof + Walls
framerman
4 Stars: 13 Votes
Take a deep breath.......and release! Select the wall, click edit profile, go to the elevation view of your gambrel roof and edit the wall lines, You can make it any shape you want. I usually just shoot off my lines in any ol direction, then use the align tool. Lines out of parallel will almost always go into alignment when you do it this way.
Gambrel Roof
Thu, Jul 13, 2006 at 8:48:34 AM
Creating Gambrel Roofs
Fri, Mar 31, 2017 at 9:59:39 AM
Roof, Roof, Tower and nary a boolean to be found
Thu, Apr 8, 2010 at 5:02:02 AM
Gambrel roof with gable slope?
Mon, May 25, 2020 at 8:52:41 AM
exterior walls above a lower roof
Sat, Feb 26, 2011 at 1:52:16 PM
Page generation time: 2.2680
