12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Angling Wall Sweeps
I want to put a freize board where the wall meets the roof. I was going to use wall sweeps but I can't figure out to get the wall sweeps to angle where there is a gable roof. Is this possible with wall sweeps or do I need to look at doing it differently? Any help would be appreciated. Thanks.
The best way I found is to use a roof fascia sweep, attach it to the outside edge of the roof, then you have to manually move it against the wall.
Hope this helps
Thanks Framerman! Just what I needed.
Is there an easier way to do this?
3 Posts No Rating |
Use reference lines. not reference planes to make the angle reference you need. Reference lines have end points and are designed specifically for that purpose. I hope this helped.
Did this change for version 2011? I created a roof fascia but it will not let me move it. We jumped a few versions and am still trying to figure out where things are. How do you make a reference line?
There is a vertical profile offset that can be used to move teh facia up/down in relation to the roof edge.
BTW - The poster above yours that said to use reference lines .... If they know how to have reference lines in the model, I would like to know. They are available in the family editor, including in-place families but not in the model environment.
How do you move it back to the wall @ gable roof locations?
There is also a horizontal offset but your question suggests you need a different solution. Attached is a simple in-place sweep that will automatically join at the corners.
Edited on: Mon, Aug 15, 2011 at 1:27:13 PM
Walls with automatic wall sweeps |
Fri, Aug 31, 2012 at 3:58:55 AM
Outlets and Wall Sweeps |
Wed, Feb 29, 2012 at 9:39:46 AM
Wall sweeps line weight |
Wed, Apr 30, 2008 at 10:59:05 AM
Wall Sweeps |
Sun, Jul 12, 2009 at 1:54:07 PM
13
Vertical Wall Sweeps |
Thu, Sep 13, 2012 at 7:52:24 AM
12
