Forums >> Revit Building >> Technical Support >> conical roof generation
Thu, Oct 19, 2006 at 4:07:36 PM | conical roof generation
huycke
3 Stars: 1 Votes
One of my students would like to generate a conical roof over a round wall section in his house. Does REVIT 9.0 have the capability to do this? If so, can someone point me in the right direction? Thanks
Thu, Oct 19, 2006 at 5:14:15 PM | RE: conical roof generation
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Easy. Use Roof by footprint. Draw a circle and set it to be slope defining Set it segmentation to 0... There you go.
Regards,
Chris.
Thu, Oct 19, 2006 at 6:43:57 PM | RE: conical roof generation
framerman
4 Stars: 13 Votes
Wow, do I feel stupid. I didn't know you could set it to 0. I always made a mass and converted it to a roof. Thanks again Mr. Spot
Thu, Oct 19, 2006 at 11:02:20 PM | RE: conical roof generation
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
hey mr. spot, do you know if it is possible for the surface pattern to show when the segments are set to 0? I always set this with several segments for my pattern to show Thanks,
Fri, Oct 20, 2006 at 8:25:35 AM | RE: conical roof generation
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
anyone know?
Tue, Oct 24, 2006 at 10:57:47 PM | RE: conical roof generation
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unfortunately surface patterns will not show on a curved surface in revit. Post edited on 2006-10-24 22:58:18
Regards,
Chris.
Wed, Oct 25, 2006 at 6:58:28 AM | RE: conical roof generation
Yohan
On the subject of "surface patterns will not show on a curved surface in revit." I have had several different experiences where I can see the surface pattern using model patterns on a wall with a raduis but found that when I applied these surface patterns to elements in a sweet it seems to disapear. Any explanation, please anyone.
Joining a conical roof to a gable roof or other rectangular roof
Tue, May 28, 2013 at 9:29:25 AM
Conical Roof Framing
Fri, Feb 22, 2013 at 6:07:12 PM
Revit 2015, Conical Roof Surface Pattern Twist
Wed, Apr 22, 2015 at 8:57:44 AM
Spiral stairs that follow a conical wall
Mon, Feb 4, 2008 at 4:46:33 PM
Pat file generation
Mon, Aug 26, 2013 at 2:17:43 AM
Page generation time: 2.7986
