Forums >> Revit Building >> Technical Support >> Almost done with job - have a bearing height I need to change - changes 1st flr
Wed, Oct 18, 2006 at 3:33:49 PM | Almost done with job - have a bearing height I need to change - changes 1st flr
mpenn
1 Stars: 1 Votes
Almost done with this project and I need to change the bearing height 8" up. Problem is the Main Level is locked somehow to the 2nd floor bearing height. So when I change the 2nd floor bearing height up 8", the main floor moves up 8" and messes up my RCP too. (RCP based on Main floor.) I've tried a couple of things, but I can't seem to determine where I locked it. Help!
Thu, Oct 19, 2006 at 1:36:59 PM | RE: Almost done with job - have a bearing height I need to change - changes 1st flr
mpenn
1 Stars: 1 Votes
I finally figured out where to change it...I used the activate dimensions button while in a section and off the right appear a lock. Unclick it and there it was...changed finally. For some reason, the lock doesn't show up in my elevations. Not sure why. Maybe I locked it in a section. Anyway, it's fixed.
2nd flr walls not lining up with first floor walls
Wed, Jun 16, 2010 at 2:20:42 PM
Relative Revit Levels.
Mon, Sep 15, 2014 at 9:58:19 PM
CUT PLANE IN wINDOW
Tue, Jan 12, 2010 at 4:30:40 PM
WINDOW CUT PLANE IN 2010
Thu, Jan 7, 2010 at 10:38:27 AM
Revvit 2016 porch/deck height help please
Tue, May 12, 2015 at 3:01:03 PM
Page generation time: 2.7942
