30 Users Online (28 Members):
Forums >> Revit Building >> Technical Support >> how to remove unwanted loaded family
32 Posts No Rating |
i want to remove unwanted loaded family becos to reduce the file size....any body knows out there ??????
58 Posts No Rating |
purge the revit file...that will take off everything not used in the project..and a huge reduction in space too...
"purge the revit file...that will take off everything not used in the project..and a huge reduction in space too..."
how to purge can u please explain.....thanxs
Go to File-->Purge Unused...
Then select what you do or don't want to purge. I always deselect curtain wall mullions cause they can cause issues if you need them back later.
Regards,
Chris.
thanks chris
Post edited on 2006-10-20 07:36:01
roof remove cut segment |
Fri, Jun 1, 2007 at 6:44:44 PM
WALL CUT (openings) MATERIAL |
Sat, Sep 28, 2013 at 10:56:04 AM
Remove Working Views from Revit Projects with Python Shell Script |
Mon, Mar 25, 2013 at 12:43:53 PM
when i turn on my room's interior fill, i get an unwanted blue outline |
Wed, Jan 28, 2015 at 8:52:00 AM
loaded revit family |
Mon, Feb 4, 2013 at 8:11:07 AM
