21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> Tough one - Phased site topography and visibility in section
8 Posts No Rating |
Really need help on this one - I have an existing site with a 'new construction' graded region comprising cut and fill. The existing topography is set as 'demolished' in the 'new construction' phase. In section the demolished topograhy shows as a dotted line - perfect - but I can't turn the 'cut fill' off. See attached example.
Thanks
29 Posts No Rating |
In View Properties under phasing set phase filter to "show previous an new"
8 Posts No Rating |
'show previous an new' effectively removes the demolished topography but that's not what I'm after... I need to see the demolished line(dashed) indicating the natural ground level. I'm trying to see the dashed line without the fill associated to the demolished topography.
Thanks for the intrest tho
24 Posts No Rating |
Hello, Has anyone out there found a solution to this problem below since 2006??! I'm wondering exactly the same thing. Cheers
Not an ideal fix, but it may work for you...follow the link for a video. http://www.screencast.com/users/MOwens/folders/Jing/media/13fb1f9f-bfc3-4ba1-bf86-a953826fcaf8
Link a copy of the existing site with the site/settings/poche to assigned as none (ie no poche) – The hatch won’t come through. Having the existing site not be part of the modified site can be easier on the brain. The proposed site model can be just for proposed work. There is no risk of modifying the existing accidentally.
For anyone trying to do this, Select the 'existing' topo --> right click --> overide graphics in view --> by element --> select surface pattern --> untick 'visible' --> then click 'transparent'.
These steps will remove the associated cut fill and also stop the blank white of having no pattern blocking the rest of the model by maing it transparant.
Site plan visibility problem with graded region |
Sat, Jan 8, 2011 at 12:57:02 PM
Subregion and Phasing |
Tue, Jan 25, 2011 at 4:19:36 PM
Importing site plan to do a 3D topography |
Sun, Jan 29, 2006 at 11:53:50 PM
Topography |
Wed, Oct 19, 2016 at 6:19:21 AM
Topography box missing? |
Fri, Nov 11, 2011 at 2:53:17 PM
