Forums >> Revit Building >> Technical Support >> Cut plane for doors and widows different from plan!!
Wed, Oct 18, 2006 at 2:44:47 AM | Cut plane for doors and widows different from plan!!
eday
When I view door and windows in plan the cut plane appears different to the plan - for example - I see a cut through the very top of the door frame when the view range for the plan is set at 1.2m. Help!
Wed, Oct 18, 2006 at 5:22:30 AM | RE: Cut plane for doors and widows different from plan!!
nandini
there could be a difference in the cut plane value in the family...check that..
Wed, Oct 18, 2006 at 6:15:11 AM | RE: Cut plane for doors and widows different from plan!!
eday
Thanks - that does seem pretty obvious - I had been searching for the view range of the family in 3D view - note to self....... and anyone else - you can only adjust the view range in plan.
Wed, Oct 18, 2006 at 6:17:20 AM | RE: Cut plane for doors and widows different from plan!!
eday
hmmm... may have spoken too soon - have adjusted view range in family - cut in project is still bad. Anyone have any other suggestions?
Wed, Oct 18, 2006 at 8:41:37 AM | RE: Cut plane for doors and widows different from plan!!
latemore
latemore Avatar
3 Stars: 2 Votes
as the experts remind us - families are tricky. only been at this revit for 2 years, but i find the visibilty settings in families to be very important. maybe check that? eg "only show if instance is cut"? not sure what else to suggest.
Cut Plane
Wed, Nov 19, 2008 at 7:03:50 PM
Uisng - Plan Region with Clearstory Window above Doors
Wed, Mar 31, 2010 at 8:16:04 PM
Doors are missing in plan
Fri, Jul 22, 2011 at 8:42:47 AM
Showing High Windows Cut In Plan
Mon, May 28, 2007 at 3:09:47 PM
Windows and doors an=bove and below the cut plane
Mon, Jun 27, 2011 at 2:33:07 PM
Page generation time: 0.8474
