19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> HORRIBLE PERFORMANCE
1 Posts No Rating |
Revit 7 May have new features but its starting to act like windows 3.1. After 20 min of use the entire program crawls to a hault. Why do properties windows take 5 seconds to load now? Why when changing view preferences (furniture on, furniture off) take more time then rendering a small scene? I do not know, someone at autodesk did not do their homework?
Autodesk the new Microsoft? You be the judge.
agreed, seems very slow doing simple things.
23 Posts No Rating |
I haven't got 7 yet, but if it gets quicker if you exit and restart Revit then I suspect the dreaded Memory Leak has reared its head. Bring up the Task Manager and keep an eye on the process's memory usage. If it keeps going up without ever dropping significantly then I would suspect the worst. I hop enot though, because you'd expect the s/w engineers to have checked it before they release it(!!!)
1 Posts No Rating |
Only download latest version: Revit7.0_20041113_2030.exe. There is no slowdown after a while in this compilation. PS: Redrose was right.
22 Posts No Rating |
I have heard at AU the first download version of 7.0 has a memory leak, which eventually fills up all of your RAM but has been fixed ....
Tops of the walls applied to mass looks horrible |
Mon, Jan 5, 2015 at 10:45:47 AM
Slow Model? – How to Increase Revit Performance |
Thu, May 23, 2013 at 2:22:22 PM
Posted Performance of Currently used/tested Revit Systems |
Wed, Apr 21, 2010 at 9:35:29 AM
12
Revit 2013 slow performance in citrix |
Wed, Nov 5, 2014 at 11:03:13 AM
PERFORMANCE RELATED TO MOUSE |
Fri, Feb 9, 2007 at 2:34:04 PM
