Forums >> Revit Building >> Technical Support >> Creating curb that conforms to a topography
Tue, Oct 17, 2006 at 10:39:57 AM | Creating curb that conforms to a topography
badfish
I have recently been working on a rendering and it is coming along nicely...except for the fact that the site is still lacking. The project sits partially on a hillside so I have been able to create the topo itself and get the building placed. The view I want is from the parking lot and the transition from the grass and sidewalk areas looks wierd at the same level. I've been able to split the surface and drop the asphalt parking area down but am having trouble trying to put a curb between the two. Does anybody know how I might do this so that the curb conforms to the topography I have?? It seems to me that it would have to be some sort of sweep or extrusion around the outside of the parking surface but I can't find anywhere to do this.
Thu, Oct 19, 2006 at 7:11:37 AM | RE: Creating curb that conforms to a topography
eday
luckyfish* There's a tutorial on exactly what you're after called "Complex Slabs and Paths" under tutorials. Good luck
Mon, May 7, 2007 at 4:16:07 PM | Creating curb that conforms to a topography
Atomsk
5 Stars: 3 Votes
I'm going to resurrect this old thread to ask where is this tutorial^^^  i want it!
Revit 2010
Mon, May 7, 2007 at 4:19:51 PM | Creating curb that conforms to a topography
coreed
coreed Avatar
4 Stars: 16 Votes
here's the link
http://www.revitcity.com/tutorials/complex_slabs/
you will find all the tutorials under the Resources section
HTH
Edited on: Mon, May 7, 2007 at 4:27:30 PM
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, May 7, 2007 at 4:20:19 PM | Creating curb that conforms to a topography
Atomsk
5 Stars: 3 Votes
Nevermind, i found it.
Revit 2010
Mon, May 7, 2007 at 4:21:04 PM | Creating curb that conforms to a topography
Atomsk
5 Stars: 3 Votes
ooh, you're quick.
Revit 2010
Tue, May 8, 2007 at 10:07:45 AM | Creating curb that conforms to a topography
Atomsk
5 Stars: 3 Votes
I can't get step 8 to work Sad
 8.   In your project, click the ?Massing? tab and choose ?Place Mass? go to 3D view for a better view.
Place mass doesn't work.  When i click "place Mass" it won't let me choose anything.
 Also, i don't think i understand step 9.
Revit 2010
Tue, May 8, 2007 at 10:55:48 AM | Creating curb that conforms to a topography
KimWong
KimWong Avatar
3 Stars: 2 Votes
Hi Guys, This is great. I too have been looking for this answer but couldn't figure if it could be done at all by Revit until NOW. Thanks coreed for the lead to the tutorial. I will sure try it out the tutorial.
 All this while I use photoshop to "cheat" on the pavement conforms to topography. Ha..ha.
Thank mates.
G'day mate. I am migrating to Sydney, Australia. Looking for Revit Architect position. Any taker? Thanks. Kim Wong.
Fri, Jul 13, 2007 at 4:49:50 PM | Atomsk
Atomsk
5 Stars: 3 Votes
Quoting Atomsk from 2007-05-08 10:07:45
This still doesn't work.  I can't choose anything to place the mass.  It will let me chose a face, but after that nothing happens.  It's frustrating
Revit 2010
Fri, Aug 17, 2007 at 1:05:52 AM | Creating curb that conforms to a topography
MazterMind3212333
3.5 Stars: 7 Votes
Yup, got the same problem here..I cannot place the mass on any views. It seems like it is looking for a host to attach to, is that right? Help please, thanks.
Wed, May 18, 2011 at 8:21:28 PM | Creating curb that conforms to a topography
ezarun
Cant get past Step 8, is there any other way to get the Kerbs to host the Topo.?
Arun
BIM Manager,
STH
Thu, May 19, 2011 at 10:58:57 AM | Creating curb that conforms to a topography
RJarrin
Try creating a profile of the curb wnated, then use the sweep command.
Thu, May 19, 2011 at 11:12:39 AM | Creating curb that conforms to a topography
#13
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
If you are going to do a lot of this type of thing one might want to consider this add-on. I have not done that as yet but think about it from time to time. The attached is the way I have done some road work it is very accurate but a little time consuming. The result is pretty good.
Thu, May 19, 2011 at 11:13:23 AM | Creating curb that conforms to a topography
#14
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Sorry,
Missed the add on. http://www.eaglepoint.com/products/siteworksforrevit/index.html
Sat, Jun 2, 2012 at 9:15:31 AM | Creating curb that conforms to a topography
#15
mneglia
I posted a free tuturial on how to create a 3D curb on a sloped site on my website. I hope it helps!
http://michaelneglia.com/2012/03/curbappeal2/
Revit blog: www.bimeveryday.com
street/curb solution
Sun, Jul 6, 2008 at 9:44:06 PM
Creating levels below topography/raising topography?
Fri, Apr 12, 2013 at 1:22:50 PM
how to add elevation to curb sweeps?
Fri, Feb 4, 2011 at 3:54:40 PM
Line Based Curb family
Thu, Nov 8, 2007 at 10:02:28 AM
How do I make curb
Wed, Dec 14, 2011 at 3:57:42 PM
Page generation time: 2.5340
