Forums >> Revit Building >> Technical Support >> How do I assign materials to a solin extrusion?
Tue, Oct 17, 2006 at 2:25:39 AM | How do I assign materials to a solin extrusion?
jrogers
jrogers Avatar
3.5 Stars: 3 Votes
Hi all, Just wondering how i can assign a material to a solid extrusion which ive modelled as a solid form? Normally ive applied decals to it to get the textures I want but this seems tedious as i have to assign textures to all 4 sides of a solid usually. thanks Josh
J-Ro
Tue, Oct 17, 2006 at 8:20:08 AM | RE: How do I assign materials to a solin extrusion?
framerman
4 Stars: 13 Votes
Welcome Josh. You have to assign the materials to the object. Depending on what it is, you can select the item, right click and select properties. In there somewhere is a way to change the materials properties. If you've created a mass object you have to convert it to something first, a wall, roof, or floor. For the project, you also want to check out the Settings>Materials section and also the Settings>Object Styles section.
Tue, Oct 17, 2006 at 6:42:52 PM | RE: How do I assign materials to a solin extrusion?
jrogers
jrogers Avatar
3.5 Stars: 3 Votes
I think i figured it out. istead of going Properties/Edit|New/ then look for the material section (which isnt there) what i should have done was... Click Object then Edit/Click Object/Properties/Material Drop down arrow/accu render texture button and done! thanks framerman
split face tool on curved extrusion
Thu, Nov 20, 2008 at 3:33:50 PM
13
Family Extrusion Materials are rotated
Thu, Sep 22, 2011 at 10:32:22 AM
No Materials in Family Editor?
Tue, Jun 16, 2009 at 8:23:25 AM
EXTRUSION YES/NO PARAMETER
Mon, Apr 28, 2014 at 4:04:36 PM
11
re-joining (?) cut extrusion with extrusion
Tue, Apr 17, 2007 at 10:26:27 PM
Page generation time: 1.1069
