Forums >> Community >> The Studio >> Wall hatch question
Mon, Oct 16, 2006 at 4:35:34 PM | Wall hatch question
Marissa
How do I show a hatch pattern in existing walls? I've figured out to make the hatch show for a new wall, but have been unsuccessful in making it show on an existing wall. Thanks for any help!
Tue, Oct 17, 2006 at 11:24:59 AM | RE: Wall hatch question
kesflower
3.5 Stars: 11 Votes
hatch pattern in elevation or in plan? I'm assuming you mean plan. You need to go into your phase settings and alter the cut view of your existing phase. I usually set mine to have a thin black line and a grey solid fill cut pattern, but you could easily change it to any fill pattern in any color. Its either under Settings - Phases - Graphic Overrides and click the little down arrow of the material, or go directly to Settings - Materials - and it should be Phase-Exist and you can change how it appears. Then play with your phase filters and those settings to get the correct phase and graphic overrides to show up in your drawings. Hope this helps.
Ruth Rau
Main Street Architecture, P.C.
Getting Cut Wall Hatch to move WITH the Wall
Fri, Aug 10, 2012 at 2:59:50 PM
Hatch pattern on a wall
Thu, Mar 29, 2012 at 9:00:21 AM
Hatch Question
Fri, Jan 9, 2015 at 10:31:30 AM
Orientation of Hatch files
Fri, Sep 15, 2006 at 12:54:43 PM
how to fix distorted hatch pattern on wall?
Fri, Jan 18, 2013 at 6:18:29 PM
Page generation time: 3.6676
