21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> How To Save Revit Drawings into Scale Image.
8 Posts No Rating |
Hi. i can save as an imge (jpG). I can plot to scale.
But how do i save an image of the drawings in scale .?
PLEASE HELP !
Thank YOU.
I hope I understand you correctly.
File>Export>Image. In the dialog box there's a section called "image size" click to 100% and you have a jpeg at the correct scale.
However, if this is what you are doing, I'd ask myself why. I just did a test run. A jpeg at 300 dpi resulted in a file of 2.1 mb, whereas a pdf/dwf at 1200 dpi resulted in a file of 84 kb. Huge difference.
8 Posts No Rating |
oh .that's it ?.thanks man.
i already try that. but i cant find the menu for the resolution actually in PDF.
by the way, i'm using PDF995.
Post edited on 2006-10-17 00:02:01
I might be getting the wrong idea here - but what's with the 'export' option? Surely you should just be printing (as you would to a standard printer or plotter) and saving as a pdf. You'll need a PDF plot driver that works for larger paper sizes (i.e. A3, A2, A1, etc)
There are many lovely programs out there - i use CutePDF - best of all, it's free! =)
revit into photoshop to scale |
Thu, Jul 19, 2012 at 12:37:09 AM
scale image |
Fri, May 13, 2016 at 1:11:44 PM
Changing the scale of a Bump image for rendering |
Mon, Sep 26, 2016 at 1:03:41 PM
How to save family drawings to pdf file? |
Thu, Aug 25, 2016 at 11:46:26 AM
changing the scale of my room and area tags with the scale of my area plan. |
Fri, Oct 22, 2010 at 10:38:38 AM
