Forums >> Revit Building >> Technical Support >> Quoin corners
Sun, Oct 15, 2006 at 6:01:30 PM | Quoin corners
framerman
4 Stars: 13 Votes
I saw a thread about quoin corners. Unfortunately it didn't work so well. I'm hoping someone can help me with the concept of making a wall based quoin corner family. Is there any way to make it parametric? Is there really any way to make it so it wraps around two walls that are perpendicular to each other. I don't quite have the concept of how to make a family to wrap around like this. I'm hoping someone can help me. I will gladly post it to the family explorer.
Tue, Feb 20, 2007 at 9:12:34 AM | Quoin corners
blake
3 Stars: 2 Votes
basically it attaches to one wall and you have to position it at the corner.  I will attach the simple one I used.  You could add more parameters too it easily enough.
Tue, Feb 20, 2007 at 9:39:51 AM | Quoin corners
coreed
coreed Avatar
4 Stars: 16 Votes
i think there are some more examples in the dowlnload area also
HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Feb 22, 2007 at 8:40:16 AM | Quoin corners
ajacobs
Sometimes I find Parametric designs more troublesome than they are worth, but I guess that is because I haven't spent enough time working out the bugs.
For my complex stucco designs, i.e. window sills, banding, keystones, etc., I always just create in place families, because that allows me the maximum amount of flexibility.
I guess I need to hit the books again on parametrics!
Quoin stack
Sun, May 10, 2009 at 4:44:28 PM
quoin stack in Revitr2008
Tue, Sep 25, 2007 at 7:44:27 AM
Is it possible to to do Brick quions at exterior wall corners?
Tue, Jan 12, 2010 at 1:09:09 PM
Align textures at corners in 3D views
Fri, Sep 28, 2018 at 1:18:20 PM
wall corners to automatically create extrusion
Tue, Nov 28, 2017 at 8:30:09 AM
Page generation time: 0.0296
