Forums >> Revit Building >> Technical Support >> Mouse wheel zoom
Sat, Oct 14, 2006 at 11:09:04 AM | Mouse wheel zoom
theskat
I have an attached monitor to my laptop while using Revit. I like to drag my Revit window from the laptop monitor to the larger attached monitor. Unfortunately my mouse wheel zoom does not work properly in the attached monitor. My drawing just disappears when I spin the wheel. If I drag the Revit window back to the laptop monitor, the wheel zoom functions properly. Is their some ridiculously easy solution to this? I'd appreciate some advice on this. Thanks.
Sun, Oct 15, 2006 at 3:14:34 PM | RE: Mouse wheel zoom
peterhaag
I have had problems in the past with this as well. One thing that seemed to resolve it was to use the "wheel troubleshooter" that is built into MIcrosoft's Intellipoint Mouse software. If you don't have that feature in your "mouse software" you may want to try downloading the latest version. Of course the other possible solution (which you have probably already tried) is to change the function of the wheel button in Control Panel. The new versions of the mouse software that Microsoft has come out with has lots of options for what the wheel is able to do. Good luck.
Mouse wheel scroll vs zoom option
Thu, Jan 17, 2013 at 12:29:59 PM
Alternative ways to zoom pan in Revit Structure
Fri, Dec 4, 2015 at 12:12:40 PM
Zoom Issues
Sat, Dec 1, 2012 at 4:32:57 AM
Mouse Scrolling
Sun, May 15, 2005 at 8:29:12 PM
zoom controls
Tue, Mar 10, 2009 at 10:47:47 PM
Page generation time: 1.9078
