Forums >> Revit Building >> Technical Support >> material assignment problems
Fri, Oct 13, 2006 at 7:49:29 AM | material assignment problems
daudesign2
I have cut a floor into 5 differerent slabs, each with it's own name. I assign materials to one and the other 4 assume the same properties. How do I make each slab maintain it's own material property?
Fri, Oct 13, 2006 at 8:13:10 AM | RE: material assignment problems
ArchWestCY
4.5 Stars: 7 Votes
In the properties dialog click Edit/New then Duplicate and give the new slab a unique name. Then change the material to be whatever you want. Repeat until you have enough different slabs for your project. You could leave them as one type of slab, and use the Paint Bucket to paint them with a different material. I guess you said 'I have cut a floor into 5 differerent slabs, each with it's own name'. So, it sounds like you have the first part right. When assigning materials have you been duplicating the material type, or just changing the type each time. Try, for instance, if your material is carpet and you want another carpet, you will need to duplicate the carpet material type, then change the material within that type. Hope this leads you in the right direction. ArchWestCY
MATERIAL ASSIGNMENT
Wed, Oct 4, 2006 at 9:22:28 AM
What should I ask before hiring an assignment writing service?
Thu, Dec 4, 2025 at 12:40:49 PM
Material Update Confusing
Sat, Jul 26, 2008 at 7:50:28 PM
material assignment glitch
Thu, Jan 21, 2016 at 1:42:10 PM
Possible for an object to rotate a material?
Thu, Sep 2, 2010 at 8:22:46 AM
Page generation time: 0.8634
