Forums >> Revit Building >> Technical Support >> Suspended ceilings in plan view
Fri, Oct 13, 2006 at 2:55:47 AM | Suspended ceilings in plan view
EsaFin
Hello, How do I make ceilings visible in plan view as an overhead line?
Fri, Oct 13, 2006 at 7:07:13 AM | RE: Suspended ceilings in plan view
akccrox
raising your view properties cut line would make your ceiling visible in plan view but it would also defeat the purpose of your RCP's
Fri, Oct 13, 2006 at 11:40:32 PM | RE: Suspended ceilings in plan view
Erik
Lift the view range to make your ceiling visible. Use the Linework tool to chenge the line style. Set VIEW RANGE back and you should see the selected ceiling lines. It is actually the ceiling not just a line. Was this what you were after?
Sat, Oct 14, 2006 at 6:00:08 AM | RE: Suspended ceilings in plan view
Search
I think Esafin is from Finland. In Finland ceiling areas are marked in plan view with dashdot line which goes the ceiling area from corner to corner. This line should be symbolic line which should be presented only in plan view. I believe that this is quite specific style to mark ceiling areas and it's not included in Revit yet.
Lighting without ceilings
Mon, May 26, 2008 at 12:56:00 PM
Suspended Ceiling Family
Thu, May 1, 2014 at 9:04:10 AM
Suspended Lighting
Fri, Jul 18, 2008 at 3:47:13 PM
Ceilings not showing
Fri, Aug 12, 2011 at 9:10:52 PM
How to model suspended ceiling in revit 2017
Sat, Nov 23, 2019 at 7:58:34 AM
Page generation time: 1.2395
