13 Users Online (11 Members):
Forums >> Community >> The Studio >> Break Marks
23 Posts No Rating |
Ok, I have searched everywhere and can not find how to put in "Break Marks" in my detail views. I created one as a symbol, but it disapears if it goes past the crop region and I can not trim things to it (like insulation). Any ideas?
29 Posts No Rating |
BREAK LINES ARE PUT IN AS DETAIL COMPONI9ENTS. YOU'LL FIND THEM IN THE IMPERIAL LIBRARY.
Post edited on 2006-10-12 17:11:37
Thanks for the help! I knew it was there somewhere.
28 Posts No Rating |
Great how do I make the wall section collapse now?
Do you mean - "How do I split the view'? Look in HELP at this topic Resizing Crop Regions Graphically After you split the view, use the double end arrows to drag the portions closer together. You will have to play with this awhile to learn how close you can bring them together without the portions re-joining. Here is a clue - the more you are zoomed in, the closer you can bring the sections together.
Thanks. I'm retarded. If anyone else is having this problem the little squiggly line on the section box breaks the section apart and then you can resize and move the sections independently.
"Referenced From" Issue with Section Marks |
Mon, Feb 6, 2012 at 2:55:01 PM
Heavy End Tick Marks disappear |
Thu, Jul 15, 2010 at 1:55:44 PM
Showing break lines with Ramps and Stairs |
Mon, Jul 30, 2018 at 11:02:36 AM
Break Line & Weld sybol families |
Wed, Apr 28, 2010 at 9:18:41 PM
Room tags, floor marks etc. misplaced in the mirrored plan |
Wed, Aug 29, 2018 at 2:37:35 PM
