16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Finnish Color
12 Posts No Rating |
I want to create my own color of stucco, so I select stucco/tan/texture in acurender (The only choices are Tan,beige,grey, and white), then i change the color in the shading box, but it has no effect on the color when i raytrace. HOW do i change the stucco color to my choice? besides the limited options i'm given.
To change what accurender sees, you have to make a new material with a new jpeg for the image map. I think the easiest way to do this is open the image in a program like photoshop, change the color there, do a save as, then make a new material copying the existing stucco material. There should be a tutorial about making a new material in your help menu.
Hope this helps.
Ruth Rau Main Street Architecture, P.C. |
I'm not positive if this is the best way to do it, but this is what I do. I find the file used for the mapping, edit the colors in photoshop or paint, save as a different name (ie blue stucco) then replace the map associated with the material, which is buried deep, deep, deep in the material/map editor.
Post edited on 2006-10-12 11:17:56
WALL CLEANUP |
Sun, Jan 17, 2016 at 6:53:02 AM
Flat color on curved surface, same color on foreground & background |
Wed, Aug 10, 2011 at 7:16:06 PM
why shading material color gets overridden by surface color |
Wed, Apr 25, 2018 at 9:53:40 AM
room color off |
Tue, Jan 10, 2012 at 11:03:58 AM
color fill is gray? |
Sun, Mar 4, 2007 at 2:28:00 PM
