21 Users Online (19 Members):
Forums >> Revit Building >> Technical Support >> composite column
24 Posts No Rating |
Is it possible to have a composite column?
Firinstance: Show concrete as cut pattern and show a different material on elevation.
It sounds like you've answered your own question. You can make a new material and assign it to your column and give it the accurender qualities that you want to see in elevation and perspective views and then change the cut material for your plan views. As long as you keep you material names straight, you can have any cut pattern with any surface pattern with any accurender material.
hope this helps.
Ruth Rau Main Street Architecture, P.C. |
It helps a lot.
Thanks.
composite columns |
Mon, Aug 31, 2009 at 10:17:41 AM
Column Bubble Size |
Tue, Oct 30, 2007 at 4:45:37 PM
composite panel walls |
Fri, Feb 25, 2011 at 1:32:37 PM
Making a Composite Mechanical Roof plan |
Mon, Sep 27, 2010 at 4:33:50 PM
Composite facade cladding (FRP FACADE FOR RAK GATEWAY) |
Fri, Feb 14, 2014 at 7:47:52 AM
