16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Revolving Door for Curtain Wall
I'm looking for a revolving door that can be inserted into a curtain wall/panel. hjacobs uploaded Revolving_Door_722.rfa to Revitcity back in 06/2003, but I am having trouble with it after I upgrade it to 9.1?
Thanks in advance.
Mark Mates
OK, no one responded to say that they had a revolving door family for a curtain wall/panel.
Does anyone care to look at the attached door family that I’m having issues with? It is a family that was created in June of 2003. I upgraded it to 9.1. The door can't be loaded into a project after it is upgraded. I figured out that there is a problem with the right glass extrusion. When you go to edit it, the lines need to be deleted. So I delete them and try to recreate them similar to the left glass extrusion. I can get the door to work OK, except that it must be inserted into a panel that is exactly 7’-4” wide. I’ve got it to work somehow in wider panels, such as an 8’-0” one, but the right glass extrusion will shoot out too far. ???
Again, credit should go to hjacobs for submitting the original door.
Thanks in advance,
Mark Mates
2 Posts No Rating |
not sure what's wrong, but figured out a way around it. if you don't mind using it as a mass, you can copy and paste the entire thing into a project. something wrong with the way the masses join so that when revit goes to compute the surface area, it gets an error that the old version didn't find.
in the family libary that comes with revit under curtain wall panels there is a revolving door. hope that helps.
had a quick look at the family, there is a problem with one of the constraints but didn't have time to find out why, but try this start a new family -curtain wall panle-copy and past in the all the objects from the old revolving door. you will have to do some fixing of constraints ect. but does work.
Revolving Door |
Fri, Jun 13, 2008 at 10:39:34 AM
Curtain Wall Panel to Curtain Wall Door |
Mon, Jun 23, 2014 at 9:32:11 AM
curtain wall door |
Tue, Jan 31, 2006 at 1:36:58 AM
Curtain wall door frame |
Mon, Mar 2, 2015 at 11:37:33 AM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012 |
Thu, Jul 7, 2011 at 4:27:10 PM
