Forums >> Revit Building >> Technical Support >> image export
Wed, Oct 11, 2006 at 10:58:06 AM | image export
Ghassan
Hi...i would like to ask about exporting my projects to a jpg file so as i can send it to the planning portal for approval. the problem i am having is that i am exporting the sheet which is A3 and i am getting very bad quality picture. u cant read the writings and it is not scaled. so is there away to export an A3 sheet and get a scaled photo and the quality is good. thanks for ur help!!!
Wed, Oct 11, 2006 at 11:57:00 AM | RE: image export
ArchWestCY
4.5 Stars: 7 Votes
JPEG is the wrong way to go. Anytime you export to a raster image, you are going to loose quility. The best bet for exporting to a file that you can share is .dwf or .pdf. .dwf is an Autodesk file type that Revit is ready to use. The problem is that you have to convince the recipiant to download and use the .dwf viewer. .pdf is much more common and accepted, but you need a third party .pdf writer in order to plot to this format. I use .pdf Xchange. They offer a free version that includes a plot stamp saying it is a trial version. The pro version only cost $50 U.S.. AutoCAD has a .pdf writer built in. I would think it is only a matter of time before Revit includes its own .pdf writer, as well. Ask the Planning dept. if they will except .dwf. They may already use it. Hope this helps ArchWestCY p.s. to export to a .dwf go to the File menu and down to Export DWF then choose 2D DWF, and select the sheets that you want to export. FYI 3D DWF exports a model that others can look at for free.
Wed, Oct 11, 2006 at 12:05:28 PM | RE: image export
framerman
4 Stars: 13 Votes
Is your sheet A3 3d or 2d? If it's 2d, you don't happen to have a pdf printer driver do you? If it's 3d, do yu have another program such as ADT with Viz or 3ds max? This is what I'm thinking. If you have a sheet and you're trying to get quality out of it, you're jpeg to accomodate is going to be a huge file. A pdf file will be maybe 200 kb max and you will have unsurpassed quality. A 3d drawing you can get super quality from max compared to the renderer in Revit and have a reasonable size jpeg to boot (maybe 2 mb's) Are you giving them the file? Or sheets? Edit: Hehe posting at the same time. I agree totally with ArchWestCY. There are free pdf drivers out there. You have to look for them. I used to use FoxIt pdf editor before I got Acrobat Pro. You might be able to get a trial download from adobe without any stamping. Might want to check them out first. Post edited on 2006-10-11 12:10:16
Export an Image shortcut help.
Wed, Feb 10, 2021 at 10:33:57 AM
Image export
Sat, Oct 24, 2009 at 6:25:00 PM
Incorrect Image Export Size
Mon, Apr 12, 2010 at 3:18:51 AM
HELP! I just rendered an Image and it wont export or save!
Fri, Oct 14, 2011 at 9:59:04 AM
Capture Rendering/Export Image
Wed, Aug 15, 2007 at 10:34:26 AM
Page generation time: 0.2567
