Forums >> Revit Building >> Technical Support >> Ceiling Views not showing
Wed, Oct 11, 2006 at 9:15:31 AM | Ceiling Views not showing
6slinger
1 Stars: 1 Votes
Hi Has any one had any problems with their ceiling veiws not showing? I have the rooms drawn up and it should appear as an underlay in the ceiling plan but absolutley nothing is appearing in Ceilng Views 1 or 2. Kirk
Tue, Apr 27, 2010 at 1:00:48 PM | Ceiling Views not showing
ndelalio
I have the same problem only the ceiling plan was there, I put in lights, did some rendering exercises to confirm the locations are what I wanted then the plan vanished.  The ceiling is still there but I cannot get it to view on the ceiling plan.  I can modify it in the floor plan if I select it in section then edit in plan but nothing shows up in the ceiling plan.
I have opened the file using the audit function and that has not corrected the problem.
Any suggestions?  Version 9.1
Tue, Apr 27, 2010 at 1:08:35 PM | Ceiling Views not showing
4 Stars: 205 Votes
In that Ceiling plan, if you use the TAB key near the limits of the ceiling you can selected, you are using a "Plain" ceiling with out a "Pattern" right?
Floor and Ceiling Surface Pattern not showing in some 3D views
Tue, Apr 11, 2017 at 6:55:32 AM
CEILING NOT SHOWING
Thu, Oct 30, 2008 at 11:35:13 AM
Section not showing ceiling
Fri, Jun 14, 2013 at 11:17:08 AM
ceiling plan, light fixture not showing
Sun, May 24, 2015 at 5:05:30 PM
Ceiling Level Keeps Showing up
Sat, May 29, 2004 at 10:33:13 AM
Page generation time: 0.3826
