Forums >> Revit Building >> Technical Support >> Cutting floor slab edges out of pads
Mon, Oct 25, 2004 at 6:41:13 PM | Cutting floor slab edges out of pads
renee
I used slab edges as floor thickenings on a pad. The earth cut pattern of the pad overlaps the slab edges (making it look quite a mess). Does anyone know how to cut slab edges out of pads? Do I just switch off the pad in section and draw a filled region around the whole thing? Any suggestions? Anybody? Renee
Mon, Oct 25, 2004 at 10:43:54 PM | RE: Cutting floor slab edges out of pads
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Typically we just use filled regions in section views to represent the earth. Until we are able to specify thicknesses to topographical surfaces its really the best method...
Thickened Slab Not Cutting Floor Line Out
Wed, Dec 28, 2011 at 7:54:13 AM
Tagging floor slab edges
Thu, Feb 9, 2006 at 2:02:28 AM
Topo PADS
Sat, Sep 29, 2007 at 3:41:40 AM
Slab Egdes & multicategory schedules.
Mon, May 16, 2011 at 2:04:35 AM
slab edges are brown
Thu, Apr 28, 2011 at 8:58:20 AM
Page generation time: 1.9542
