Forums >> Revit Building >> Technical Support >> Adjusting project levels for multi storey building
Wed, Oct 11, 2006 at 1:17:06 AM | Adjusting project levels for multi storey building
A5Len
We are working on a project which is fairly well advanced, and have just been told that the entire building needs to be lowered by 450mm. Can anyone help with suggestions on how to do this with the least amount of changes - there are quite a few drawings with drafting lines complimenting the model (I am hoping that these will not have to be individually adjusted if the level drops) Any help would be greatly appreciated
Wed, Oct 11, 2006 at 8:33:31 AM | RE: Adjusting project levels for multi storey building
latemore
latemore Avatar
3 Stars: 2 Votes
this is annoying but from our experience, it can be done, but not quickly. the trick we find is to renumber levels from bottom and work your way up. most things will work, but odd things go nuts. i think you can move the viewport in views which also moves drafting lines, but i could be completely wrong. experiment first and see what happens. another thing is to check out the level parameter settings on the base level - i have had limited success with this, but i remember there was an extensive bit in help about changing settings of one level, then link others to it, then move that one level - have a look. and lots of better revit users suggest linking buildings into a master file. that way you can move whole buildings - look in help? hope my silly ramblings help, but the experts will know more.
Tips on setting up a multi storey and multi unit residential model
Wed, Aug 3, 2011 at 8:35:26 AM
Editing Multi-Level Building
Wed, Jul 20, 2011 at 11:11:04 AM
Setting up a Multi Storey building best practice for beginners
Fri, Oct 7, 2016 at 1:55:24 AM
Revit Architecture 2008 Multi Level Stairs - Complex Building
Sun, Dec 4, 2011 at 4:39:37 AM
Mysteriously Linked Levels in multi-level Building
Mon, Feb 8, 2010 at 3:01:47 PM
Page generation time: 2.0823
